dlnoss Posted November 23, 2003 Report Share Posted November 23, 2003 gumby, The head comes with orings, it doesn't require different studs. Pro Design domes will fit and probably others that I don't know about. I've been told Vitos domes will fit. Patriot Racing will make custom cut domes if you want and I sell 17cc thru 22cc domes. frocashmoney24, I look forward to hearing from you. SICK BOY, Thanks! I'm glad you like it Quote Link to comment Share on other sites More sharing options...
yfz440 Posted November 24, 2003 Report Share Posted November 24, 2003 how much do you charge for a head noss? what are the dome sized on a stock head and what would you sujjest for a motor . 10 over w/ no porting or polishing? my current stock head is milled down .30 i think Quote Link to comment Share on other sites More sharing options...
dlnoss Posted November 24, 2003 Report Share Posted November 24, 2003 Before the BansheeHQ discount, the heads are $195 or $210 for anodized and the domes are $65. I charge a flat $6 for UPS Ground shipping in the 48 states. The dome size depends on your riding elevation, the fuel you want to run, and if the timing is advanced. Quote Link to comment Share on other sites More sharing options...
wackyatvguy Posted November 29, 2003 Report Share Posted November 29, 2003 i ride in kentucky and tennessee, +4 degree timing. what would you suggest for domes i want higher compression for more low end grunt for trail riding i run110 octane already in my 425 ex of course mixed with pump half and half but race gas is not a problem. phil Quote Link to comment Share on other sites More sharing options...
speedster07 Posted November 29, 2003 Report Share Posted November 29, 2003 Can someone tell me what torque values to torque the head with with a Pounds per square inch torque wrench thats the only wrench i can get ahold of right now. any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted November 30, 2003 Report Share Posted November 30, 2003 I strecthed 2 studs at 25ft pounds. I torque them at 23 last time. Hey Mr Noss what the setting for your head? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted November 30, 2003 Report Share Posted November 30, 2003 20 ft/lbs is plenty with the oring head. It seals a lot easier than the head gasket. Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted December 1, 2003 Report Share Posted December 1, 2003 i ride in kentucky and tennessee, +4 degree timing. what would you suggest for domes i want higher compression for more low end grunt for trail riding i run110 octane already in my 425 ex of course mixed with pump half and half but race gas is not a problem.phil im gonna guess your at around 1000 feet? give or take 500 feet, with race fuel and advanced timing around +4? you could run his 17's but if your cranks not welded id stay around 19's maybe even 20's on a stock crank with an advance of more than +4 timing Quote Link to comment Share on other sites More sharing options...
jonnyrebel2004 Posted January 23, 2004 Report Share Posted January 23, 2004 David Ok I dont know that much about this so give me a break here. I am looking into buying a coolhead for my 2001 banshee, that I just got. I will mostly be riding at Seminole OK which is around 1100 feet, but I do plan to make a few trips to Little Sahara, which I dont know the elevation of. Right now I am just running 91 octane pump gas, but I might occasionally run some octane booster or a little higer octane gas with it. Like I said I just got it, I dont know if the timing is advanced, but I doubt it. I think I would like to increase my low end torque if possible. With all that being said what size domes do you think I need? I see it says you are from OK, where are you located? I do know one thing when I do purchase one I will buy it from you. Thanks Travis Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted January 23, 2004 Report Share Posted January 23, 2004 David Ok I dont know that much about this so give me a break here. I am looking into buying a coolhead for my 2001 banshee, that I just got. I will mostly be riding at Seminole OK which is around 1100 feet, but I do plan to make a few trips to Little Sahara, which I dont know the elevation of. Right now I am just running 91 octane pump gas, but I might occasionally run some octane booster or a little higer octane gas with it. Like I said I just got it, I dont know if the timing is advanced, but I doubt it. I think I would like to increase my low end torque if possible. With all that being said what size domes do you think I need? I see it says you are from OK, where are you located? I do know one thing when I do purchase one I will buy it from you. Thanks Travis run 20cc domes johny......you will be safe on pump fuel...even with a +4 timing advance... Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted February 8, 2004 Report Share Posted February 8, 2004 so Dave, whats the total cost to a HQ memebr if I get a head with domes shipped? i keep reading different stories in different threads! Quote Link to comment Share on other sites More sharing options...
dlnoss Posted February 8, 2004 Report Share Posted February 8, 2004 With the BHQ discount, a silver head and a set of domes is $240 shipped UPS Ground. If it is an anodized head, it's $247.50 with the discount. -David Quote Link to comment Share on other sites More sharing options...
