elfsmachone Posted September 8, 2014 Report Posted September 8, 2014 ok here we go I have an 06 banshee, I have had every issue with carbs finally just got rebuilt ones from ebay, they have the delete kit on them and idle screws installed best I can tell from other people they are installed properly, here comes the crazy when I got the carbs they had a 200 main and a 160 pilot jet run it very rich on bottom end, carbs also came with stock sized jets and stock type of jet, 25, installed them just to find that the 160 jets were shorter. quad wouldn't run with the 25 in it. got some 40 and 55 swapped out will run on 55 but seams lean going to get larger pilot jets but thought I would see if anyone has any insight Quote
wayne_smith97 Posted September 8, 2014 Report Posted September 8, 2014 Can you list your mods? And we are talking factory mikuni's right? Quote
hoppedupandcutdown Posted September 8, 2014 Report Posted September 8, 2014 Banshee Mikuni stock carbs have Banshee specific pilot jets, 25, 27.5, 30, etc http://www.dfn.com/agservices/jetfaq.html Quote
trickedcarbine Posted September 8, 2014 Report Posted September 8, 2014 You aren't mixing mikuni and keihin jets are you? Huge difference. What are the mods on the bike? Quote
elfsmachone Posted September 10, 2014 Author Report Posted September 10, 2014 ok well I thank you guys for all the concern but we found out tonight that the tube between the carbs for the choke had a split in it replaced that back to a 27.5 jet thanks Quote
