What fuel should I be running in my engine?
91coupemike
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
I couldn't get my cub to run on 100ll. No matter the tune it wouldn't rev out right. All I can tell you is that switching to 93 pump cured the problem
100LL has a motor octane of 106.
You might have needed more compression.
If your Cub ran on 93......it probably wasn't making enough heat with the higher octane for the dome/pipe combo.
100ll is MON rated at 99.something. might as well call it 100.
If you run it slightly rich , it's rated up to 130 octane.
So if you want to play it safe at 100 octane , you're VERY safe.
Independent testing shows it almost exactly the same as C12. minus an additive that helps with vapor lock and helps cold starting. It has almost the exact same amount of lead as C12 too.
we run 100ll in a bunch of small engine shit to avoid ethanol. i know its not blazing fast but ran a 4.43 at kansas a month ago before we ran out of test and tune time. saying its only for air planes is like saying off road diesel will hurt your on road truck motor.
those pipes need to make heat to work. That also is a factor. Well, one of the minor ones...
