NYUK Posted September 4, 2014 Report Share Posted September 4, 2014 Whats the purpose of this mod? is the front caliper a lot better than the rear one? sometimes rear calipers are hard to come by, i have piles of fronts. it an oldschool drag strip trick, for when the rear seizes. Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted September 4, 2014 Author Report Share Posted September 4, 2014 Nyuk is the man Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted September 10, 2014 Report Share Posted September 10, 2014 What's the reason on why the bleeder screw needing to be on top to bleed? Quote Link to comment Share on other sites More sharing options...
NYUK Posted September 10, 2014 Report Share Posted September 10, 2014 if you are using a vacuum it does not. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 10, 2014 Report Share Posted September 10, 2014 What's the reason on why the bleeder screw needing to be on top to bleed?Air travels to the highest point. If the bleeder is at the bottom... Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted September 10, 2014 Report Share Posted September 10, 2014 if you are using a vacuum it does not.A vacuum? ?? Must be out my league. Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted September 10, 2014 Report Share Posted September 10, 2014 And thanks shreerider. ..I will definitely be trying this when I get home....also I heard there is some modifications that need to be done, but from what I've read and saw....seems to be none,...can some one clarify please Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 10, 2014 Report Share Posted September 10, 2014 A vacuum? ?? Must be out my league.A vacuum bleeder. Harbor freight. Cheap, works, and worth it. Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted September 10, 2014 Report Share Posted September 10, 2014 My favorite store. ...thanks again....I'll look into that as well Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted September 10, 2014 Report Share Posted September 10, 2014 I have two rear calipers that's sticking....robbing me of hp. ...if the front sticks then I'll know it has to. Be the master cylinder Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted September 10, 2014 Author Report Share Posted September 10, 2014 So all i need to do is put the rear caliper mount in the front caliper? Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted September 10, 2014 Report Share Posted September 10, 2014 Yes Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted September 10, 2014 Author Report Share Posted September 10, 2014 10 4.. it looks cleanet and i got sum super clean polished front calipers im doin it Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted September 10, 2014 Report Share Posted September 10, 2014 I put yfzs on the front of my turd and threw this one on. Worked out ok. Didn't notice any difference riding. I need to get one of those bent lines to clean things up a little. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 10, 2014 Report Share Posted September 10, 2014 I see no point in this "mod." Quote Link to comment Share on other sites More sharing options...
