I have a 421 serval shearers and 35mm pwks. Tuned 50 160. 70hp. Want to go back to stock carbs, how will it affect performance and HP? I'm thinking about 30 380.
Please don't say so you can run the stock airbox....
Yer like an idiot I got air box style. Have you guys had a problem with your thumb throttle being able to open the 35s all the way? I got a billet one atm and it don't have the leaverage to crank carbs all the way.
Dynoed it last week and found slides only open 80 - 90%
Hmmm. Bought stuff that doesn't fit. Didn't realize bigger carbs need more cable pull till paying for dyno...... I'm like an idiot? By the way it's spelled you're in that context. A period would show non nigrosity or class....
Try grinding a little material back where the stop is for the throttle. Should fix ya up. May need taller adjusters as well.
Edited by trickedcarbine
Get the right filters. The 35s are a much better carb for it IMO. If you need to you should be able to get filters thru a kart racing company. They usually have KN style filters to fit that size carb and you can get the proper angled ones.
