She has no compression
kawa110
Cute lil' rabbit hole......
If you Havnt torn it down figure out how to do a leak down. Otherwise just bank on splitting the cases and do a complete tear down. Look for anything suspicious. Could be caused by tons of factors. Just have to know the bikes history and look inside. Like playing clue, but greasier. No special procedure except the flywheel. Need a specific puller but it's cheap and does some other stuff to. Not a three jaw unless you intend on yanking the pick up right off the plate. Definitely quit jerking off on the toilet for a few days and read the Clymer instead. It's only a few days.....
Yes, that's the gauge setup you want. It already has the tire valve stem. There's no need to be doing any drilling, gluing, etc. Get 1 of these type of reducer bushings. The kind that's supposed to be glued into a fitting. Find the one that fits your intakes. Then get threaded adapter bushings to adapt that gauge set up. seal everything with silicone sealer or teflon tape. Plug the other intake with the same type of PVC fitting.
For the exhaust, use your stock Banshee front bumper rubber end caps or buy 2 of these type caps at the hardware store.
Here's the type of pump I use
Soon trickedcarbine, soon. LOL
