booxzzy Posted August 29, 2014 Report Posted August 29, 2014 Hi guys,i think i need 27.5 pilot jets but just wanna make sure im right about that. -Sea level - 35 degrees celsius (95F) - fmf gold series and power core 2 silencers -K&N in box air filter without lid -280 main jets -25 pilot jets -v force 3 valves Since i installed vf3 valves the bike doesn't wanna idle at all,i cleaned carburetors and changed the needles so it got me to think its cause of the pilots,need your opinion,thanks Quote
bluebanshee98 Posted August 29, 2014 Report Posted August 29, 2014 At least a 27.5 pilot. Usually fmf's like 30's. 1 Quote
Evans Ward Posted August 30, 2014 Report Posted August 30, 2014 FMF recommends 30 pilots in their instructions when you purchase their pipes. I really think either size pilot will work with tuning with AS adjustment. Quote
Nightmare Posted August 30, 2014 Report Posted August 30, 2014 FMF recommends 30 pilots in their instructions when you purchase their pipes. I really think either size pilot will work with tuning with AS adjustment.Yeah but does FMF know what's done to every banshee motor running around? No! Each setup will want something different depending on the build. Quote
Nightmare Posted August 30, 2014 Report Posted August 30, 2014 It specifies stock motor with intake I'm pretty sure.Thank you for pointing that out special, I see it now. Quote
booxzzy Posted August 30, 2014 Author Report Posted August 30, 2014 tnx guys,i really appreciate your input,have to check for air leaks again and float level cause it seams like I'm getting way to much fuel all around(spiting unburned fuel out of exhaust) float needles and seats have been already changed,i also removed boost bottle and plugged the holes for good. Quote
fastbanshee8 Posted August 30, 2014 Report Posted August 30, 2014 How many turns open are your air mixture screws? They should be open 1.5-2.5 turns, and make sure both are set the same. Quote
Evans Ward Posted August 30, 2014 Report Posted August 30, 2014 Thank you for pointing that out special, I see it now. Yep- stock engine is what I was referring to and by looking at the OP's specs. Did you verify float level is within spec? Seems it should be about 21mm if memory serves me right? Quote
