trickedcarbine Posted August 27, 2014 Report Share Posted August 27, 2014 No way!! Powder can be thick and uneven Rzr blade it after it's qtip'd with acetone This is about the best way for said scenario. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 27, 2014 Report Share Posted August 27, 2014 I was kidding. Honestly if they were mine I wouldn't have PC'ed the cases. They look worse than bare aluminum when they are all dirty. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted August 27, 2014 Report Share Posted August 27, 2014 Sheww!! I was hoping so booker. Lol. Quote Link to comment Share on other sites More sharing options...
jcam Posted August 27, 2014 Author Report Share Posted August 27, 2014 i'll give it a try thanks Quote Link to comment Share on other sites More sharing options...
Burke Posted August 27, 2014 Report Share Posted August 27, 2014 get one of the green roloc discs with all the little fingers on it... do a good hard tape line where you don't want it removed and be careful Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted August 27, 2014 Report Share Posted August 27, 2014 I think the best way it with acetone or MEK, but it sucks because they evaporate fast. I used MEK to strip my A-Arms, and it took it right off. Sanding just plugged up the paper, and don't like using Roloc disks on gasket surfaces that are aluminum. I would probably opt for a long flat file b4 the rolocs. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 28, 2014 Report Share Posted August 28, 2014 get one of the green roloc discs with all the little fingers on it... do a good hard tape line where you don't want it removed and be careful Who in their right mind is using Rolocs on gasket surfaces? Quote Link to comment Share on other sites More sharing options...
Burke Posted August 28, 2014 Report Share Posted August 28, 2014 if you know what you're doing, it won't remove any metal Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 28, 2014 Report Share Posted August 28, 2014 if you know what you're doing, it won't remove any metalNote to self, NEVER, buy cases or cylinders from burk. Sorry, I get the thought and I've seen a lot of guys do it and say it's fine, or that they aren't removing material, if there material removed it's supposedly minimal enough to where the gasket will still seal. I'm not a believer. Just my thoroughly educated opinion. Quote Link to comment Share on other sites More sharing options...
03DMshee Posted August 28, 2014 Report Share Posted August 28, 2014 And if you use MEK...for christ sake put a fucking mask on...that shit is lethal! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 28, 2014 Report Share Posted August 28, 2014 Right from 3m site about the roloc bristle heads. I use them. I've used a straight edge after using them. When I worked at the dealership, every head gasket job we used them. I haven't read anywhere but here not to use them. Quote Link to comment Share on other sites More sharing options...
