Banshee Cylinders
Ok, rife. You don't just measure all over in the top. You have to actually measure inside the bore at different depths. Best result, let an engine builder/machinist fit the bore with the intended pistons.
He'll no! This is just to ball park a cylinders life only.
This is legit. Measure in as many points as you care to remember or write down. The industry standard I believe is now 6 points so the drawing is old.
Sent from my iPhone using Tapatalk - now Free
If the tool is clocked 90* at each measurement height to measure front to back then side to side yes that makes 6 points. But I guess I didn't even pay attention to the part where it shows A & B for each height.
