Elevation: 1500 ft
Temp: 60 to 80
Mods
Engine: vitos 397cc 4 mil long rod
Head: pro design cool head. 22cc domes
Exhaust: Toomey t5s
Intake: no airbox lid. K&n filter w/outerwear. Tdr intake w/internal crossover tube.
Carbs: 34mm Keihin PJs
Electrical: 3° advance timing plate
I'm currently rebuilding my motor. Going from stock bore to 66mm. Stock mikuni carbs to 34mm pjs. Also adding the cool head, tdr intake and advance timing plate. I haven't dealt with keihin carbs before and I would like some input on where I should start jetting wise.f86b57c7a0dfb32a14c4dd2d4492c28e.jpg
not really that combo will get you close may need to move needle around a bit.  just check your plugs.  my 4 mil with PJs and T5s ran 160s at sea level and was a bit fat
Idle..... Screw both choke knobs clockwise so that they are all they way in. Use paint pen, white out, tape, or something to put a mark on both knobs so you can keep track of where they are rotation wise. Not turn them both 7-7 1/2 turns out. Should idle nice.
