trickedcarbine Posted September 19, 2014 Report Share Posted September 19, 2014 Probably fine. Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 19, 2014 Author Report Share Posted September 19, 2014 Aight. I should get a compression test done. 80-90 hours on the motor since last rebuild and still running fine. Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 19, 2014 Report Share Posted September 19, 2014 The proper bit costs me like $13 at the tool store. Then I spent $45 on a Mattoon. Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 20, 2014 Author Report Share Posted September 20, 2014 Well I finished my plate and got it mounted, out the stator on, put the flywheel and key on and set the coil pick up and I am impressed! I weight 200lbs and I was putting around my backyard blinking 1/4 throttle and the acceleration is tremendous! I was popping wheelies like crazy! Here's a video of me revving it. I had to adjust my air screw a tad but it is all good now. I hold it WOT in neutral and it revvs all the way to top end in only a second, no bogging or spuddering. Also helps idle. Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 20, 2014 Author Report Share Posted September 20, 2014 Also I've been meaning to ask this, the right exhaust doesn't put out smoke when it gets around 3/4 throttle. When the RPM's drop it starts to smoke again and smokes at idle. No backfiring or anything so is this something with my carbs? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 20, 2014 Report Share Posted September 20, 2014 It's burning better up in the RPM's could be a few different reasons but if it sounds like it's firing ok and doesn't have a bad looking plug I wouldn't worry. Ever watch videos of drag bikes that just make a 20 foot cloud at the line but once it's wide open it's burning pretty clean. Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 20, 2014 Author Report Share Posted September 20, 2014 Hmmm the left one smokes as it goes down. Well I pulled the plugs to check on them and the right plug got fouled because I was running the air screw too rich. So I put new plugs in and now the right cylinder isn't even firing. I put my hands behind the exhaust and the left exhaust is nice and warm but the right is cold. It only smokes and is warm at 1/2 throttle so I am going to take the carb apart and clean out the pilot and main and see if it changes. I should take a look at my reeds too. Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 20, 2014 Report Share Posted September 20, 2014 You done went and blowed it up! So it was firing, you changed plugs and not firing anymore? Or same issue? Plug boot on nice and tight? Kiss Keep it simple stupid! Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 20, 2014 Author Report Share Posted September 20, 2014 Nevermind I found out the right carb was out of sync. When I cracked the but loose the entire hex cap that goes over the throttle broke. I will have to order a new carb top and hex for the cable. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted September 20, 2014 Report Share Posted September 20, 2014 So ummm.... Thoughts on the grinding?... Other than it looks like shit what the fuck...how is that slotted it just looks savaged Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 20, 2014 Author Report Share Posted September 20, 2014 It worked. I took a drill and elongated the wholes 4mm and it fit on the engine case fine. I can hear it sparking a lot faster now in the exhaust. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted September 20, 2014 Report Share Posted September 20, 2014 well ok i guess if it works Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 20, 2014 Report Share Posted September 20, 2014 It worked. I took a drill and elongated the wholes 4mm and it fit on the engine case fine. I can hear it sparking a lot faster now in the exhaust.That's not slotted. I'm sure you're going to argue, saying "it run GREAT", but you haven't slotted that near enough Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 20, 2014 Report Share Posted September 20, 2014 It takes about 1.25-1.5 mm of slot to get 1° of timing advance. You should be within around 1.5mm of the trailing edge of the plate to get 4-4.5° of advance. Quote Link to comment Share on other sites More sharing options...
ETR174 Posted September 21, 2014 Author Report Share Posted September 21, 2014 It takes about 1.25-1.5 mm of slot to get 1° of timing advance. You should be within around 1.5mm of the trailing edge of the plate to get 4-4.5° of advance.Shieeetttttt Quote Link to comment Share on other sites More sharing options...
