a arms for 450 shocks
m671054
Messaged recieved.
Thank you Burke for thinking of us!  You're my boy Blue!
Banshee HP nice set up man!
Yes.  Stellar Machine and Performance does make Banshee A-Arms for YFZ450 front shocks.  The J-Arm and A-Arm Banshees both share the same lower arms.  So doing the conversion on either is no problem.  We do need to know at the time of ordering whether 450 shocks will be used or not.  The lower shock tabs need to go in a different location in order to;
A: Clear the YFZ shock (Ie. grinding down the tabs so the shock will fit)
B: Keep proper ride height and arm travel due to the 1" longer shock.
Our arms are designed around stock Banshee spindles and should be used to keep proper alignment and ball joint travel.
You can call me at the shop (520-481-6946) or message me anytime.  If I don't know.  I can always find out!
