a arms for 450 shocks
m671054
450 shocks are longer and drop the a-arms low enough to damage ball joints and give a pretty severe toe-in when the front suspension is unloaded.
I have 450 shocks on my Banshee with Full Flight +2 +1 arms. I cutdown the mounts by an inch, and turned them out slightly.
Now when the front suspension is unloaded, the a-arms drop the same distance they did with the stock shocks.
In reality the geometry of the steering and suspension pretty much sucks! I like the mod that some of the guys here are doing by welding on a whole front stub and suspension from the 450.
So you dont have aftermarket arms built for 450 suspension? i thought that the were setup to allow for a slightly longer shock. Maybe i went about this all wrong. What are the longest shocks you can run stock, +2, +2 yfz style, long travel is around 19.5 ive read.
I know that. I have j arm and was trying to figure out what was so different on the lowers to run the 450 shock. I wasnt gonna run stock 450 but thought a longer aftermarket shock would be nice
Aren't the lowers on the A arm and J arm the same? (Not positive) maybe they could set you up with just the lowers? Or even just buy a whole set up. Might even be possible to hi their website and see what differences you can visually make out. Edited by trickedcarbine
