Pros and cons about Boyesen reeds?
Pros:
Better then stock
Cheap if you find used
Still replacements available
Cons:
Out dated
Replacement parts are the same price as VForce
Not gonna perform as well as any VForce.
Their cages have that weird flute that needs to be ground on or your manifold needs modifying if you are using anything other then stock or UPP manifolds.
Imo.. not all builds need vf. Stockish bikes won't see the gains like the bigger more high strung builds. This was proven on the dyno with the vf2. And no one has posted a dyno of a stock bike comparing them since. I use chariot cages with power reeds. I've used power reeds and switched to vf and couldn't feel a difference. Imo.. unless it's a drag build or something larger then 4mil.. not worth the price.
Same here. A little "play" motor that you don't need every last HP,,,, stock modded cage and boyesons work good.
I dont mind boyesons, as long as your not trying to get every ounce of power. I run them in duners all the time.
