YFZ Conversion questions
Hi, I am doing a Banshee engine conversion on my YFZ. Sitting on the arse end of the globe makes it difficult but through beer and sweat it must fit!
I have a couple of questions> What is the base jet sizes for running a 380 stroker with stock carbs and FMF Fattys?
                                                I will be using the stock YFZ radiator fan and rectifier but a Banshee harness without TORS.
                                                How do I wire the YFZ rectifier to the Banshee stock stator to charge a tiny sealed batt?
                                                I do not have a Banshee rectifier.
Any help will be appreciated.
Thanks
290-350 mains on stock carbs.
i am pretty sure you cannot make a banshee stator work with the yfz regulator.  try baja designs regulator for floated ground style set ups.  banshee's do not have a rectifier  they have a voltage regulator thats only for running lights.
Thanks for the info guys. I'm floating the earth from the Banshee stator to the other yellow or white.yellow on the YFZ regulator rectifier. Keeping the charging system apart from the ignition system. If I manage to blow something up it's my bad.
  • 2 weeks later...
  • 4 months later...
  • 9 months later...
