If it weren't for one of the teeth being wedged in the gears I probably would have never know it happened. What should a set of gears cost?
You can buy complete transmissions from $100-125.
Yup. 87-12. Do your self a favor and spend a few bucks
- modded trans
- new shift forks
- new shift shaft
- new eccentric screw
- new cable
- new pressure plate, hub, basket and clutch (if old one is all stock or worn)
- new locking tab for eccentric bolt and basket bolt
That's all I'm thinking off the top of my head. There might be more.
- modded trans
- new shift forks
- new shift shaft
- new cable
Very large investment, however the return is huge. A reliable smooth operatin machine that if maintained, will last a good while
