tylercaz99shee Posted August 11, 2014 Report Share Posted August 11, 2014 Aright i picked up a 86trx250r for really cheap but its not running right. i got a heck of a deal and i know its worth more in parts but id like to getting it running right so i can make my banshee a dune quad and the trx a trail quad. Please no crap for me having a honda atleast its a 2 smoker . Alright it starts first or second kick but it never has any power. it feels like the plug is getting gummed up, but it never clears out or opens up. I put a few new plugs in it, changed the gas(running premium with klotz 40:1) checked compression, cleaned air filter, took silencer off to make sure it wasnt packed full of shit. and nothing helped. Im thinking its either reeds or cdi box. Any suggestions? how do i tell if the reeds are bad? Quote Link to comment Share on other sites More sharing options...
2strokes4u Posted August 11, 2014 Report Share Posted August 11, 2014 Carbs cleaned? Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted August 11, 2014 Report Share Posted August 11, 2014 Make sure the Reed petals aren't chipped and that they close completely. Quote Link to comment Share on other sites More sharing options...
hp2000 Posted August 11, 2014 Report Share Posted August 11, 2014 Check the jetting ? Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted August 11, 2014 Report Share Posted August 11, 2014 Doesn't sound like its jetted right Quote Link to comment Share on other sites More sharing options...
tylercaz99shee Posted August 11, 2014 Author Report Share Posted August 11, 2014 carb has been cleaned. Guy said it ran fine last summer but hasnt been touched sense then, and the jets havent been changes. He also said it would idle fine. Now it wont idle. The plug looks wet. but its not too bad. i dont think it is the jetting. also looked up jetting and its pretty on point. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 12, 2014 Report Share Posted August 12, 2014 It's missing a cylinder....... 2 Quote Link to comment Share on other sites More sharing options...
03DMshee Posted August 12, 2014 Report Share Posted August 12, 2014 It's missing a cylinder....... Was thinking the same thing.... Quote Link to comment Share on other sites More sharing options...
oldskool Posted August 12, 2014 Report Share Posted August 12, 2014 You say compression was checked, how much? Stock 250r should come outta the box at around 170, not 125 like banshee Quote Link to comment Share on other sites More sharing options...
Piediddy Posted August 12, 2014 Report Share Posted August 12, 2014 If your gonna keep it the first thing I would do is buy the CR ignition kit for it. Let us know what compression is, sounds like carb issues. I had 4 R's from a 370 Duner to 443 Puma drag bikes. Pound for pound and comparing CC's they the baddest bike ever built. Mainly used for MotoX because of power and Geometry. Wish I woulda kept mine. Quote Link to comment Share on other sites More sharing options...
tylercaz99shee Posted August 12, 2014 Author Report Share Posted August 12, 2014 Compression was 170. the reeds look good. Next is im going to take the flywheel off and see if the key is sheared. Aslo i have a feeling it may be burning gear oil. The plugs get pretty wet fast, and smokes a lot for premium gas with klotz 40:1 Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted August 12, 2014 Report Share Posted August 12, 2014 Did u change from a different premix ratio? Quote Link to comment Share on other sites More sharing options...
tylercaz99shee Posted August 12, 2014 Author Report Share Posted August 12, 2014 I am not sure, but it was running like crap when i got it so i cleaned the carbs, and drained the gas. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 12, 2014 Report Share Posted August 12, 2014 Compression was 170. the reeds look good. Next is im going to take the flywheel off and see if the key is sheared. Aslo i have a feeling it may be burning gear oil. The plugs get pretty wet fast, and smokes a lot for premium gas with klotz 40:1If it's burning the case oil, then the crank case has a leak somewhere. Which could be a culprit of your issues. It's passed a leak down with the covers off the motor? Quote Link to comment Share on other sites More sharing options...
tylercaz99shee Posted August 13, 2014 Author Report Share Posted August 13, 2014 I have not done a leakdown test, nor have i ever done one. I am almost posative that its the crank seals at this point but i will do a leak down before i replace them. Thanks for all the help, and not giving me that much crap for ridding red (: Quote Link to comment Share on other sites More sharing options...
