Purchasing Cheetah - How to identify CC? HELP!
Today I will be going to look at a banshee that has a trinity racing cheetah motor in it. The guy got the bike on a trade a few years back and it has been sitting in his garage every since. He is an older (wealthy) gentleman and just wants to get rid of it so I will be picking it up for a steal. 5 hrs on the motor.  He says it is a 500cc but when asked if its 485cc or 535cc kit he has no clue.
He claims that the motor and everything was a cost to the tune of 8K. And from the pictures I see - I can already identify about 2k worth of parts.
- Stage 5 exhaust
- Aftermarket Mikuni Carbs (not sure mm?)
- Billet deep carb bowls
- Billet clutch cover
- billet stator cover
- Billet stage 5 head
- K&N Filters
- Crank is stroked but he doesn't know how big
All from trinity
http://postimg.org/image/d6nfe8ycl/
http://postimg.org/image/m2y7i6oyt/
http://postimg.org/image/weakaugo5/
Is there anyway I can identify the size of the motor without opening it up? What about the carbs? Any other important questions I should be asking? I have owned banshees my whole life but don't know too much about the cheetahs. Pictures below - THANKS!
I hope you can afford to spend another $2000-$3000 on it after you get it home......
  • Like 1
Glad I asked first - he wants to trade me my stock yfz for it (picked it up for $1500.00 from someone desperate to sell) so I thought this would be a good way to make a buck or two especially because I want to get back on a banshee...
Like i said - older rich guy who doesn't want something that fast
So this thing doesn't have trinity motor in it? How can you tell? Why would he have those big @ss carbs on it and other trinity sh!t if nothings going on. THANKS FOR THE FEEDBACK!!!
Edited by dgwizdal
That is NOT a CHEETAH! That guy is clueless. The cylinders do look welded up though and it looks like it was a good job. That can definitely be a pretty hot running little motor if it's ported well and dialed in. I would go over there and show this guy this thread to show him he's lost. And if he was conned, then he's an idiot for not doing exactley the same research you are.
To check size, you gotta get a view of the number on the piston for the bore size. At the very minimum, you can check stroke easily though. Run a dowl down the spark plug hole and rotate the motor over and mark the dowel at it's highest and lowest point. Measure it in MIllimeters. 54mm is stock stroke, 58mm is 4mm stroke, 61mm is 7mm stroke. With that set up there won't be anything bigger in there.
Here is a fucking cheetah
Sent from my iPhone using Tapatalk - now Free
  • Like 1
Other than a motor the nobody knows anything about.....that bike has NOTHING else done to it.
Junk tires on stock rims. Plastics and rims are from different years, so it coukd be and older bike with newer plastics or newer bike with older wheels.
What octane fuel does it need? How can you trust the answer? Black trinity pipes, IMS motorcycle shifter?.....that's some old shit! Was it ever jetted correctly? Trinity head = Trinity domes. Do a search on that topic! LOL
Too many questions..........
No base gasket. Just cylinders bonded to cases.
Doesn't look like a stroker to me.
At best that's an Old School sleeved 68 bore build with a stock stroke crank.
it could be a 10 mill if it has the spacer in the head..
ask for reciepts from all the motor work.  if he is a wealthy rich guy i cannot thing of to many at least around here that dosent keep every damn reciept they have.
What do you mean by welded up? Thanks again - I may go over there just to let this guy know that A. He's full of shit or B. He got ripped off.
The sides of the cylinders look to have a little weld on them from the pix. It is a mod you used to see pretty commonly before all the aftermarket cylinders came out. Guys would build up the aluminum by tig welding over the area the ports flow through the cylinder. Thus, allowing more material to be removed inside the transfer ports. For all we could know, that motor could run great, but no one knows, and what you've been told so far has been total garbage.
Update: you guys were right! Had 69mm pistons in it with big bore sleeves. I passed on the offer...
Showed him the thread and he was cool about it and got a chance to learn as well.
If anyone in Chicagoland has a banshee for trade let me know or else ill be back when I pick one up.
Thanks bros
