Pipe Problems
Ok so I finished the lower end of my 4 mil just yesterday and I wanted to test fit the pipes but I still don't have pistons so I just put the cylinders on to test for the pipes. They are FTZ out of frames and they don't seem to mount up correctly, almost like the spots where the spring clips to are in the wrong place. Anyone here had FTZ or maybe not and might have a solution to my problem. I can post a picture if needed.
Okay so here is the problem. First of all the places where the springs do not look like they are in the correct spots or maybe there is a different way to mount out of frames (first set ever).
Now i put one spring on and you can see what happens. I dont understand why the other spring holder is not on the bottom like any other inframe pipe.  Usually the inframes have one on top of the pipe and another one farther up the pipe but directly under it, but the FTZ are like an inch from eachother.
And the second problem i see is the space between the foot peg and the pipe, i have seen some pipes that need a mount built because they sit farther away from the peg so thats probably the solution to that problem but my main question was where to i put the springs so these are mounted up correctly? is there a specific way to do out of frame pipes?
Edited by jriffe23
