billybobby Posted November 21, 2014 Author Report Share Posted November 21, 2014 Not being able to produce cast carbs on time is/has been their big issue. I dealt with Chad and he really seemed to want make sure I was taken care of. These carbs kinda make efi irrelevant unless you are wanting a turbo setup or running differentry tunes for gas, e85 or alky. Plus I lost a little over 12lbs ditching the efi! I guess if the metering rod is off it might be a pain but mine worked good for my 7mill and the new 10mill. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 21, 2014 Report Share Posted November 21, 2014 aftermarket / hybrid chassis are a waste 1 Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted November 21, 2014 Report Share Posted November 21, 2014 aftermarket / hybrid chassis are a waste^^^ bozo ^^^ Lol 2 Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted November 21, 2014 Report Share Posted November 21, 2014 Ok so against doctors orders i couldnt help myself and wanted to see if the pipes would fit so i pulled the Snipers off and tried them on the Outlaw chassis. As you can see the head pipe will fit pretty decent. But the problem is where the mid pipe mounts the head pipe. As you can see in the pic the pipe hits the cradle tubing for the rear shock. If Gary at Srp could see the chassis he might could adjust the mid pipe to compensate but as is there is no way to get the mid pipe mounted to the head pipe. Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted November 21, 2014 Report Share Posted November 21, 2014 Might be different for the Laeger chassis because we discussed this before and i believe they are built a little different. Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted November 21, 2014 Report Share Posted November 21, 2014 Roger i have a set of Cpi's here that i have for sale. When the rain slacks off i will bring them out here and try those to see if they fit if you want to see if those would be an option for you to run. Quote Link to comment Share on other sites More sharing options...
billybobby Posted November 21, 2014 Author Report Share Posted November 21, 2014 Thanks for checking that out Brian. I found some cheap cpi's and some shearer's... I'm going to give them both a shot. I think the way the rear shock is mounted will be the issue for most pipes. I should be able to make them fit with some tweaking. The trinity's are nice cause you don't need pipe clamps for the silencers. Really there is just not a lot of room on these outlaws. Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted November 21, 2014 Report Share Posted November 21, 2014 No theres not a whole lotta room back there. Funny thing is tho i can pull the motor out of that chassis faster than i can a stocker! Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted November 23, 2014 Report Share Posted November 23, 2014 billybobby , did you have to make any changes / adjustments to your smart carbs with your new 10mil serval? Quote Link to comment Share on other sites More sharing options...
billybobby Posted November 23, 2014 Author Report Share Posted November 23, 2014 4 clicks different then my 7mill motor. Runs perfect! 1 Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted November 23, 2014 Report Share Posted November 23, 2014 Good deal Quote Link to comment Share on other sites More sharing options...
99michael Posted March 10, 2015 Report Share Posted March 10, 2015 4 clicks different then my 7mill motor. Runs perfect! What fuel ratio you running? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 11, 2015 Report Share Posted March 11, 2015 are you still running yours^ i thought i read you were going to take them off Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 11, 2015 Report Share Posted March 11, 2015 I wish u were closer I would bend you new miss but I need the bike I front of me I'm not taking any chances Quote Link to comment Share on other sites More sharing options...
99michael Posted March 11, 2015 Report Share Posted March 11, 2015 are you still running yours^ i thought i read you were going to take them off Yeah, got rejected for a refund. Lmfao.... I ran em' in Oklahoma last fall ride, and it wasn't so bad. So I guess I'm gonna just roll with it an keep tinkerin till Its right. I wish u were closer I would buy you new ones but I need the bike in front of me. I'm not taking any chances ^ is this what your tryin to say? Lol, Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
