trickedcarbine Posted July 26, 2014 Report Share Posted July 26, 2014 Is changing the clutch pretty simple. Drain oil and coolant. Take off clutch cover and springs. Put new plates in same way they came out? Sent from my iPhone using Tapatalk Sorta close. Ditch all the old o rings, the driveline and fast unit don't require you to index the plates either. Just make sure to check the old basket and hub for grooving/wear. Quote Link to comment Share on other sites More sharing options...
10milmike Posted July 26, 2014 Report Share Posted July 26, 2014 I have been using driveline clutchs for a long time. I have always said lane sells a good clutch. His plates he uses are yfz 1000 that hold more heat. They work great for asphalt. Quote Link to comment Share on other sites More sharing options...
