slapahobanshee Posted July 25, 2014 Report Posted July 25, 2014 It's a 65mm bore cub on stock stroke and is dune ported with pj 34 mm carbs Sent from my iPhone using Tapatalk Quote
Surfrjag Posted July 25, 2014 Report Posted July 25, 2014 it could be lean or it could be that its a stock stroke cub and doesn't have much bottom Quote
slapahobanshee Posted July 25, 2014 Author Report Posted July 25, 2014 Thought my carbs could be to big cause it jetted right Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 25, 2014 Report Posted July 25, 2014 Carbs are pretty good for that motor. Gonna be hard pressed to get much bottom out of that thing regardless. What's the overall set up? If the motor is set up ok, you may be able to work with gearing and tires. Maybe some clutch would help. Quote
