Hey Guys I was wondering if I could get a little input about the jetting I am running on my banshee. I have the following done to her:
Stock mikuni carbs with
Stock Bore Stroke on engine
compression is 120 per cyl
280 main jets
25 pilots
I am 882ft above sea level
I also have timing plate mode +4
and FMF fatty and powercore pipes
and K&N uni pods and outerwear covers
My question is do you think I should bump up my pilot jet to a 27.5 and or 30 pilot jet she runs pretty nice fires first kick but I have 8 months into rebuilding an old 91 J arm frame and I really want to be sure I don't lean her out too much a blow my motor. Any thoughts?
Well changing you pilot is not going to affect anything other than the bottom end. If it runs good and has for this long I would say you are pretty damn safe. If you were going to blow it up would have already happened
  • Like 1
I have only rode this twice since it got rebuilt and plugs looked a little on the lean side when I did a plug chop. That's why I thought I should ask she runs idles strong has no break up in power but I just thought she might be just a little too lean . I tried running a 300 main jet and she didn't like that so I thought maybe bumping up my pilot jet would help me so i guess what the hell i have had this machine apart a million times im gonna buy some 27.5 pilot and just see how it turns out.
Thanks
