ryan954 Posted July 17, 2014 Report Share Posted July 17, 2014 Hey I'm new to the form. I just picked up a 97 banshee. It's has a 4 mil and some port work. It has cpi pipes a and vforce 3 reeds. The problem that I was having was its very hard to shift to forth gear. So I ordered a some stuff from fast racing. I got a new pancake bearing, modded shift star, modded shift shaft, ez shift spring, eccentric stud, shift shaft torsion spring, clutch cable, outer hub, clutch rod and ball, and clutch arm spring. Gears 1 through 3 shifts like a charm now. But I still can't get it into 4th gear. I'm lost and dnt know what to do next. Help please Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted July 17, 2014 Report Share Posted July 17, 2014 You may have something wrong with the gear or fork. Unfortunately the only way to check them out is to split the cases Quote Link to comment Share on other sites More sharing options...
ryan954 Posted July 17, 2014 Author Report Share Posted July 17, 2014 I kinda figured that. Just wanted to make sure I covered every thing else before I opened it up.I really didn't wanna have to split the cases but looks like I have 2 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 18, 2014 Report Share Posted July 18, 2014 Since you are opening it up, you might as well send your trans out for some work if you are covering all the bases. Also, being a 4 mil it's probably about due for a better shifting trans anyway. Quote Link to comment Share on other sites More sharing options...
