Case gasket match
what jugs are going on it
Stock ported cylinders. Pics of the cylinders are in a thread I made about porting them.
The jugs are almost the size of the scribed lines on the case already. There won't be much material removed from them except for some shaping in the front of the primary transfer. Figured the way to do it would be to grind the case, mount the jugs and scribe them from inside the case, then grind the jugs.
Thanks for bringing up how thin it gets! I checked it out and if I were to bring it out to the line on the stator side, it would probably pop through. There is plenty of material everywhere else, so maybe I can get some weld in there just to beef it up.
Not worth the gains ( if even measurable).
