Fuel pump.
You will need to drill and tap the intake on one of the cylinders. Insert a barb fitting and plumb a hose to the pulse fitting of the pump. Plumb the inlet of side to the petcock. Plumb the outlet to the carbs. You will also need to make sure your carbs have the needle and seat for pump set up as well.
