srm089 Posted July 12, 2014 Report Share Posted July 12, 2014 Bought this banshee about a week ago and was missing bottom end cleaned the carbs air screws were 1 1/2 out and idle screws are most of the way in showing no threads it's got top end but low idle and a lag until wide open it has 310 mains can't remember off the top of my head for pilots bored .30 21cc domes and sst pipes I believe seemed to be a little more responsive at 2 turns out but still the lag any thing under 1 turn and kills it Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 12, 2014 Report Share Posted July 12, 2014 If it runs better with the air screw out then it should mean it's a bit fat. Granted everything else is working correctly. Could be other issues as well. Check for air leaks, ignition issues, and carb choke issues. Quote Link to comment Share on other sites More sharing options...
srm089 Posted July 12, 2014 Author Report Share Posted July 12, 2014 I remember hearing at one point in time the parking brake causing low end problems this banshee still has the parking brake and wiring the choke has been working properly I will search alittle more for air leaks I wonder is that stupid boost bottle wore a hole in its self Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 12, 2014 Report Share Posted July 12, 2014 Could definitely be parking break or any other safety electrical junk Quote Link to comment Share on other sites More sharing options...
Starwriter Posted July 12, 2014 Report Share Posted July 12, 2014 See if the slides or float bowls are swapped. Quote Link to comment Share on other sites More sharing options...
srm089 Posted July 13, 2014 Author Report Share Posted July 13, 2014 Slides are correct clipped parking brake wire which made very little difference maybe step down a pilot size ? Quote Link to comment Share on other sites More sharing options...
