yamashee02 Posted July 12, 2014 Report Share Posted July 12, 2014 ok I bought a compression guage today I first put it on the left side and kicked it on it would go no futher and it stop around 100 psi on the right side it read almost 120 psi but not quite.. IS that ok or normal??? also I got me a conewity guage and I was trying to see why my new coil was only getting spark on one side and now it not getting it on either side I couldn't get it to lit up anywhere is there is something I am doing wrong I think I may need a cdi box if anyone wants to sell one Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted July 12, 2014 Report Share Posted July 12, 2014 Sounds like the topend is wore out Check to be sure everything is right in electrical system before buying parts. Like Keyswitch and on off switch. Maybe someone local can let you try a known good cdi to confirm your suspicion. Did you trst the stator as well? Quote Link to comment Share on other sites More sharing options...
03DMshee Posted July 12, 2014 Report Share Posted July 12, 2014 Where did you get the compression gauge? Yavget what ya pay for...maybe try your local auto zone...you can borrow a known good obw drom them to double check Quote Link to comment Share on other sites More sharing options...
yamashee02 Posted July 12, 2014 Author Report Share Posted July 12, 2014 Just redone topend whats the compression suppose to b Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted July 12, 2014 Report Share Posted July 12, 2014 I believe stock is around 120~125 psi. If you have aftermarket head, domes or pistons then it can vary Quote Link to comment Share on other sites More sharing options...
Vicstuff Posted July 12, 2014 Report Share Posted July 12, 2014 Also depends on elevation but they should be even readings Sent from my SGH-T889 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Finch Posted July 12, 2014 Report Share Posted July 12, 2014 Also depends on elevation but they should be even readings Sent from my SGH-T889 using Tapatalk Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted July 13, 2014 Report Share Posted July 13, 2014 What mods do you have? What is your elevation? Why did you do the top end in the first place? Was the ignition problem present before the top end rebuild? A bad gauge won't read consistently. Try the cylinders again. If they read 120 and 100 a second time, you have a consistent gauge. Have you broken the top end in yet? At what point in the life of the current top end did spark become a problem? Quote Link to comment Share on other sites More sharing options...
registered user Posted July 13, 2014 Report Share Posted July 13, 2014 i dont see why your calling him stupid. kicking compression goes down as elevation goes up. both sides should be close to the same readings Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted July 13, 2014 Report Share Posted July 13, 2014 = I concur. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 13, 2014 Report Share Posted July 13, 2014 It also depends on how the gauge is fitted to the cylinder. If it has hollow threaded on adaptors instead of individual hoses for all the different spark plug types that will affect the reading. Any volume from the schrader valve in the hose to the tip of the adaptor is added volume to the combustion chamber. Quote Link to comment Share on other sites More sharing options...
