JJ & A Axles
Claudia,
Although I think you're a dummy, I can respect the fact that you can produce the numbers and computer simulation in such short order. You are still a dummy, but you are at least an educated dummy.
He’s the only one of the dummy’s who’s putting it to application as it applies here. The other dumbfuck is just posting general info pertaining to one diameter without application as it applies here on BHQ. Copy and paste dumbfucks
I see you have issue reading. Go back and look again.
I will make is simple for you. Solid is stronger when the OD is the same. If this is too hard to understand, then maybe you shouldn't be giving out any advise on this.
So a 7075 40mm drilled axle is or isn’t strong enough and lighter than a solid one....lmao GTFO with useless info for BHQ
is a 7075 40 mm solid axle stronger than a 7075 40mm drilled axle? how about you get the fuck out of here. Again, if this simple fact is over your head, stop giving advise on here.
Bump LOL
