naoh05 Posted July 12, 2014 Author Report Share Posted July 12, 2014 Turbo Chassis, Stellar, Tyson or Fireball. Jja have the carrier clamps is that to make ur own swing arm? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
naoh05 Posted July 12, 2014 Author Report Share Posted July 12, 2014 Ya. Build your own. Got any 2x4s to build a jig ? No not even a welder, but we'll see some day lol. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted October 31, 2017 Report Share Posted October 31, 2017 On 09/07/2014 at 7:01 PM, CottonBranchRacing said: An axle with a hole all the way thru it is less likely to bend. CottonBranchRacing " Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted November 1, 2017 Report Share Posted November 1, 2017 "What are you getting at here Claudia? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 1, 2017 Report Share Posted November 1, 2017 What are you getting at here Claudia?I was just using the search function about JJ&A axle and saw that claim who is not supported by any theorical background. Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted November 1, 2017 Report Share Posted November 1, 2017 I was just using the search function about JJ&A axle and saw that claim who is not supported by any theorical background. Envoyé de mon SM-G935W8 en utilisant Tapatalk So Josh is wrong? Quote Link to comment Share on other sites More sharing options...
Keno Posted November 1, 2017 Report Share Posted November 1, 2017 If there is a solid rod and a hollow tube made of the same material and are the same diameter, the solid rod will be stronger. A hollow tube that has the same mass as a solid rod will be stronger, but have a much greater diameter. Thus, a hollow tube can have a greater strength per mass. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 1, 2017 Report Share Posted November 1, 2017 So Josh is wrong?Yes.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
JTmachining Posted November 1, 2017 Report Share Posted November 1, 2017 One dimension vs multi dimensions. Now wat up Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted November 1, 2017 Report Share Posted November 1, 2017 Drilled is stronger than solid. Pretty simple to understand. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 1, 2017 Report Share Posted November 1, 2017 1 hour ago, specialblend07 said: Drilled is stronger than solid. Pretty simple to understand. I'm no metalurgist. But wouldn't the hole down the middle add some sort of torsional benefits? 1 Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted November 1, 2017 Report Share Posted November 1, 2017 Just now, trickedcarbine said: I'm no metalurgist. But wouldn't the hole down the middle add some sort of torsional benefits? Yes Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted November 1, 2017 Report Share Posted November 1, 2017 1 minute ago, trickedcarbine said: I'm no metalurgist. But wouldn't the hole down the middle add some sort of torsional benefits? No, if size is the same, a solid part is always stronger than hollow. https://www.engineeringtoolbox.com/torsion-shafts-d_947.html In torsional, the center doesn't do much, but it still adds some strength. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 1, 2017 Report Share Posted November 1, 2017 You have your answer on those pics.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 1, 2017 Report Share Posted November 1, 2017 10 minutes ago, ZillaFreak said: No, if size is the same, a solid part is always stronger than hollow. https://www.engineeringtoolbox.com/torsion-shafts-d_947.html In torsional, the center doesn't do much, but it still adds some strength. I also understand the strength being stronger on a solid part, but sometimes a part that can handle some flex lives longer then a heavy solid part that would rather snap then twist. At least that's my minimal experience. Quote Link to comment Share on other sites More sharing options...
