banshee won't stay running help!
I need help with my banshee. Problem is it won't stay running on its own. Also at about 1/4 throttle it doesn't respond good. I recently did the top end and it's starts right away and runs excellent at 1/2 & full throttle. Any help would be appreciated.  Thanks
97 banshee
.20 wiseco pistons
Trinity mx ported cylinder jugs
Hot Rod crank (stock size)
+4 advanced timing
V force 4 reeds
310 main jets
Needle clip middle position
25 pilot jets
Carbs rebuilt
Fmf sst pipes
Unknown silencers just all chrome but are fmf
Cool head with 20cc domes
Elevation 3780 ft
Any questions please let me know
Edited by badboyzracing187
Won't stay running, dosent have idle screws. Are you seeing the connection?
Pilots to small. Get a 30 between the pipes porting and vf4 you need 30s. Your probably lean on the bottom causing the bog.
You may get away with a 27.5 with your elevation but a 30 is safe.
One thing at a time.
Your pilot was stock on a built motor.
You need a 27.5 minimum
More likely 30's
Get slides sync'd and idle adjusted, then work on airscrew adjustments.
