like a new manchine got questios
Hey guys I have had my shee since 05 got sidetackedfor a few years and well to b honest I just got out of prison and I'm rebuilding the shee I bought some FMF fattys, Pro design cool head with 19 CC domes, ProFlow intake from prodesign and boyseen reed cage and reeds, already have installed promotion twisty, and ricky stator timing plate advanced 4 degrees, im on standard pistons, also had to buy new coil. Iguess im asking will the 19 domes be ok and really whats there purpose ..thank u
19cc domes will give that bike a substantial jump in compression. Probably more then your bike can handle with out a switch to higher octane. Especially with you running some timing. Your crank might not like the extra compression with out at least a true and weld.
That Rickey stator plate is junk. They are known to crack at the threaded part where he stator is bolted to the plate. If you are dead set on running it, keep a close eye on it. Torque it carefully and use LOCTITE(blue)
Good luck with that thing. My banshee kept me out of lots of trouble once I came home as well. All my friends were partying, I was in the garage out of. The bull shit. Perfect.
I went to prison cause some dumbass broke into my moms house and I decided to go to the guys house and beat his ass and well I got into a lot trouble cause of it...OK another question I put my new coil on today and one of the sides sparks and the other doesn't and I cant get it to run
