Atomic Monkey Posted June 30, 2014 Report Share Posted June 30, 2014 Going to be replacing my crank soon, and going to be case matching to my cylinders. What else should I do while the cases are apart? Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 30, 2014 Report Share Posted June 30, 2014 Full ProMod tranny with all the shifting mods and fresh shift forks. Pancake bearing Full clutch component inspection (including clutch badket bushings. If you don't have a billet waterpump....I would get a unit from Mull Engineering along with their metal drive gear. ALL NEW SEALS If you are just doing a crank and no port work....try the Vito's Super Stock pistons. They add 7HP and feel like mild porting. (Price is almost tge same as any other piston you woukd normally use.) Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted June 30, 2014 Author Report Share Posted June 30, 2014 Thanks John! I'm looking into the pro modded trans, what's all involved with that? I have the pancake bearing and went through the clutch last summer after a ball weld. I also ordered up a seal set, and will get a billet impeller. I'm also working on porting the cylinders, and have a set of those new Wiseco Ultra Stroker pistons ordered. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 30, 2014 Report Share Posted June 30, 2014 Modded trans is every other dog removed and maybe drum work depending on who does it. Worth it. I have it in my bike and my girls bike. Never missed a shift Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 30, 2014 Report Share Posted June 30, 2014 ^ that and other misc trans mods Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 30, 2014 Report Share Posted June 30, 2014 Yeah. Also if your gonna do it get New eccentric New tab for the nut New pressure plate New inner hub New locking tab for hub nut New shift shaft modded Shift pro kit with stock spring Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 1, 2014 Report Share Posted July 1, 2014 Here is a copy of the list I made my buddy get from fast. Qty.-1 clutch nut lock washer Qty.-1 shift rod/clutch rod Qty.-1 shift ball/clutch ball Qty.-1 shift shaft (modded) & bushing spacer Qty.-1 clutch actuator arm & washer Qty.-1 clutch cable - fast HD springs Qty.-1 stator side case plug (little rubber plug fucker) per Brent's words Qty.-2 shift fork rod plug Qty.-4 engine mount dampers Qty.-1 bearing stopper plate (behind clutch) Qty.-2 bearing stopper plate screws Qty.-1 shift drum plate o-ring Qty.-3 shift drum screws Qty.-1 shift eccentric screw Qty.-1 shift eccentric nut Qty.-1 shift eccentric lock Qty.-4 upper case/cylinder dowels Qty.-2 inner case/cylinder dowels Qty.-1 shift pro - transmission bearings Qty.-1 sprocket nut & washer Qty.-2 water jacket plugs Qty.-1 heater pipe o-ring & clip Qty.-1 kicker idler clip & washer Qty.-1 kicker idler steel bushing Qty.-1 actuator bearing Qty.-1 water pump clip Qty.-1 crank convex washer Qty.-1 case rear breather Qty.-1 fly wheel nut Qty.-1 water pump bearing Qty.-1 water pump gasket Qty.-1 rad hose from clutch Qty.-1 woodruff key Qty.-2 crank large clip (full clip) Qty.-1 trans small circle clip Qty.-1 pinguel duel pepcock Qty.-1 counter shaft/sprocket spacer Qty.-1 pancake bearing Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted July 1, 2014 Report Share Posted July 1, 2014 Cut trans shift drum bearing mod Mull shift detent bearing modded shift shaft billet impeller billet impeller drive gear port match cases Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted July 3, 2014 Author Report Share Posted July 3, 2014 Well I'm sending it to Cam for the Pro Mod, I want it to shift like butter! Quote Link to comment Share on other sites More sharing options...
