97 partout with title
Ahhhh they're meant for no brackets!!!  Well let me know if u decide to sell that cascade stator cover separately
Yes, they fit over the stock headlight brackets. They slide sideways over the brackets from the outside. I have these exact covers without the hole drilled for the headlights. I put them on to cover the brackets when I'm not running headlights. When you use them with the aftermarket headlights, as above, you must trim the outside frame bracket so that the bottom mounting nut of the headlight clears the bracket as you slide them on.
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
Got a bunch of banshee parts if anyone is interested 97 frame titled 250
White and blue plastics with matching seat cover and stainless grill $200
Skat track extreme 9 paddle haulers and itp dual rib front tires on black wheels $225
4 mil bottom end with billet stator cover and polished clutch cover $750
4 mil polished dune ported cylinders with pistons bore is 64.50 $500
Vforce 2 reeds $85
Pro design cool head wit 19cc domes need orings $100
Banshee hubs all 4 $60
+6 lsr swingarm carrier is stuck in it $150
Rear shock 75
Prices do not reflect shipping charges
Sent from my C5155 using Tapatalk
