AgelessMind Posted June 29, 2014 Report Share Posted June 29, 2014 Good day all, im hoping to get some help with and idle issue. i have a 93 banshee that was running fine until i repaired some leaks on the intake boots and clean the filters. Now the bike will not idle, I need to apply throttle to keep it running. some help would be greatly appriciated, need to get this sorted out before i sell it. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted June 29, 2014 Report Share Posted June 29, 2014 Make sure the carb slides have the cutaway towards the air filters. If they are swapped, the cutaway ends up towards the motor and it runs like crap. Make sure the choke tube is in place between the carbs and make sure the left float nowl has the brass BB at the front. Quote Link to comment Share on other sites More sharing options...
AgelessMind Posted June 29, 2014 Author Report Share Posted June 29, 2014 I looked for a tube that was out of place and I found nothing, I did nothing else other remove the intake boots. Carbs only moved enough to get to the boot bolts where they attach to the reed cage. This is my first go around with a banshee and my last, just need to get idle decent. thanks for the help so far Quote Link to comment Share on other sites More sharing options...
Starwriter Posted June 30, 2014 Report Share Posted June 30, 2014 Choke tube Quote Link to comment Share on other sites More sharing options...
