NEED HELP WITH MY BANSHEE :(
i was riding, i had just started the bike like 15 min ago, didnt even run it hard cause my shocks arent working well, and suddenly, it turned of, and there was smoke coming out of the base of the cilinder, im pretty sure it had coolant in the radiator cause i had just cheked it, and it had oil, the mix was done right... what could had happened? maybe the gasket got toasted, i didnt even tried to start it up again, cause i was afraid i might just have burned the engine... i dont know... what do you think... when i checked the water, after it turned off, it was gone... dont know :( how could it overheat if it had water and oil???? gaskets? what do you think? HELPP
  • 3 weeks later...
pull the head off then the cylinders. take a look and see if you can see any broken shit.  Base Gaskets correct? may have been smoke from the exhaust which is not sealed properly. Start there and report back some time.
