xjmav Posted June 25, 2014 Report Share Posted June 25, 2014 Need Help finding a starting point, Bike is running good at high rpms, wont idle bogs up to 1/4 throttle unloaded. Choke to start when it is warm, Don't have enough area right now to do a plug chop. From what I have read I have the wrong size pilot or plugged pilot jets, cleaning them now and they were dirty. 1) What type of aftermarket exhaust do you have?Toomey T-5 2) What type of airfilter do you have?k&N Pods3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all4) What is your elevation? 52805) What size pilot jets are you using? 25 (seems small I have 35s that aren't installed)6) What size main jets are you using? 2907) What temperature is your Banshee jetted for? unsure first time jetting Frankenstein build shooting for 90 degrees or so8) Do you have a port job? Stock porting (next mod)9) What kind of carbs? Stock10) What size carbs? Stock If it helps, I'm running a timing plate at +4, 18cc coolhead domes, stock bore, boyesen dual stage reeds, tors deleted, idle screws installed, Quote Link to comment Share on other sites More sharing options...
Vicstuff Posted June 25, 2014 Report Share Posted June 25, 2014 290ish is a good start I run 280s 27.5 pilot hmu if you need some help Sent from my SGH-T889 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Nightmare Posted June 25, 2014 Report Share Posted June 25, 2014 290 and 27.5 sound about right. I'm at 5000 and that's pretty much what my wife's banshee was at with the same mods before we switched to rockets. Sent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
xjmav Posted June 25, 2014 Author Report Share Posted June 25, 2014 (edited) I'm going to try to pick up a set of 27.5 pilots today. How do you test if pilot is ok? Cleaned the 25 and shee is actually idling now. So that's a good start! Sent from my SM-G900T using Tapatalk Edited June 25, 2014 by xjmav Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 25, 2014 Report Share Posted June 25, 2014 You know if the pilot is good by how it runs with air screw adjustment. If it runs better with more then 2-2 1/2 turns out then you would wanna go down on pilot size. If it runs better with the air screw all the way in, you may need a richer pilot. Quote Link to comment Share on other sites More sharing options...
SlowerThanYou Posted June 26, 2014 Report Share Posted June 26, 2014 We run your same basic combination using Toomey's guidelines. Our cool head has 22cc domes & run 280 mains & 27.5 pilots. Our base altitude is 2300' & our Density altitude is 5000' - 7000'. We run 1/4 mile asphalt with this set-up & have been 92 mph with this tune-up. It's hard to go wrong with Toomey's T5 recommended tune-up. http://www.toomey.com/index.php?option=com_phocadownload&view=category&id=1&Itemid=10 Quote Link to comment Share on other sites More sharing options...
xjmav Posted June 26, 2014 Author Report Share Posted June 26, 2014 I got her to idle last night with 25 pilots, 1.5 turns on air screws. Just bought 27.5 pilots and 280 mains. 21 bucks for all four! Sent from my SM-G900T using Tapatalk Quote Link to comment Share on other sites More sharing options...
