drag pipes
Because some chassis have the foot pegs welded on. And they are moved forward or backwards. Mat moves the bracket on the pipe to fit the chassis. Because all his pipes are made to fit stock pegs.
Sent from my SCH-I605 using Tapatalk
i just make a small mount between the pipes and the peg?  never thought about having to send pipes in to have the complete mount moved around..  that way if you move pipes around on differnt frames you just have the adapter to fit them on the chassis.    then just hope that each set of pipes mount on the pipe is actually in the same spot  most times they are not.  hell sometimes i have no idear where they are mounting these things too on a so called jig when they are built.
