tdod101 Posted June 21, 2014 Report Share Posted June 21, 2014 Can't seem to get the key to stay in the slot on the crank when I goto put the fly wheel on. Any tips guys ? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 21, 2014 Report Share Posted June 21, 2014 That key looks all fucked up. Do you have a new one? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 21, 2014 Report Share Posted June 21, 2014 Take a center punch and give it one center punch dimple on the side of the key where it sits in the crank. It will make a very slight raised spot on the key. Tap it into crank slot, install flywheel, happy happy Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted June 21, 2014 Report Share Posted June 21, 2014 Slot in crank straight up Key should parallel to the floor Make sure the key slides freely in the slot on the flywheel before install (slot free of crap) If the key is sloppy in the crank, get a new one Wouldn't think a drop of gasket sealer under it would hurt anything though Always lap in the tapered surfaces, too Quote Link to comment Share on other sites More sharing options...
tdod101 Posted June 21, 2014 Author Report Share Posted June 21, 2014 Doesn't seem to go past this point, key is brand new Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted June 21, 2014 Report Share Posted June 21, 2014 Looks right, does it slide easily in the flywheel off the bike? Maybe file those 4 burrs. Definitely lap in that raggedy shaft. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted June 21, 2014 Author Report Share Posted June 21, 2014 Got er! Thanks guys Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 22, 2014 Report Share Posted June 22, 2014 Lap crank/flywheel, file burrs on keyway, install tip of key on slight angle. Quote Link to comment Share on other sites More sharing options...
