Best Way To Put On Sticker Kit?
CKylesworld
clean your plastics extremely well. Don't worry about drying them. Use some soapy water and wet down the area where you're going to apply them. place the sticker down, but don't use much pressure. You should be able to move the stickers around to position them. Once positioned correctly, use something without a rough edge such as a credit card, driver's license, plastic putty knife, etc... Start from the center and work your way out, being careful to smooth out all the water and the air bubbles. Once you complete that, go over it again to make sure the sticker is adhering all the way. Let the stickers sit overnight and they'll be ready to go the next day.
Also a tip... if you have a small pocket of air that's trapped under neath a sticker and you can't get it worked out... take a very small needle and poke a hole in the middle of the air bubble. Don't force the air out fast or you might cause it to blow the hole bigger. Once the air is out, make sure the sticker is adhering to the plastic around the small hole. The hole won't be noticeable once it's sticking to the plastic.
