turbowrenchhead Posted June 20, 2014 Report Share Posted June 20, 2014 When I was taking with one of the engine builders he was taking about some of the case studs causing an air leak. What had to happen to fix this? I can't find any info on this mod. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted June 20, 2014 Report Share Posted June 20, 2014 Do yours leak or are you just asking a board question? Quote Link to comment Share on other sites More sharing options...
Nieskes Posted June 20, 2014 Report Share Posted June 20, 2014 When I was taking with one of the engine builders he was taking about some of the case studs causing an air leak. What had to happen to fix this? I can't find any info on this mod.this will show up on a leak down test, it does happen but not often. If you get enough sealant around the stud there would be no reason it would leak. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 20, 2014 Author Report Share Posted June 20, 2014 (edited) I usually install base gaskets dry with no sealant Edited June 20, 2014 by turbowrenchhead Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 20, 2014 Author Report Share Posted June 20, 2014 Do yours leak or are you just asking a board question? My current case doesn't leak. I'm having a builder do another motor with different cases and cylinders. Reusing the bottom end internals. I just want to know more about this mod. Quote Link to comment Share on other sites More sharing options...
