Case stud epoxy mod
When I was taking with one of the engine builders he was taking about some of the case studs causing an air leak. What had to happen to fix this? I can't find any info on this mod.
this will show up on a leak down test, it does happen but not often. If you get enough sealant around the stud there would be no reason it would leak.
Do yours leak or are you just asking a board question?
My current case doesn't leak. I'm having a builder do another motor with different cases and cylinders. Reusing the bottom end internals. I just want to know more about this mod.
