too_slick4u Posted November 16, 2003 Report Posted November 16, 2003 I just bought a brand new 2004 banshee today. I'm also an owner of a 03 Z400. I was wondering what's the best exhaust system the 2-stroke world has to offer. I would like to get something chrome with good increase in HP and good sound..Thanking you in advance...... Quote
Leadfoot350 Posted November 16, 2003 Report Posted November 16, 2003 Where do you ride and are you planning on porting your banshee in the future because you should!!!!!!!! There are a lot of different choices and this will help to norrow it down. Quote
Oilsmoke Posted November 16, 2003 Report Posted November 16, 2003 CPI's and Porting with K&N and the smile or Fear with last long time. Quote
too_slick4u Posted November 17, 2003 Author Report Posted November 17, 2003 mostly desert riding. Not soft sand though, very rocky and hard. Maybe in the future i think of porting if it will do me any good. Also, i'd like to mention that i have an strong interest in drag racing... Quote
camatv Posted November 17, 2003 Report Posted November 17, 2003 do this go down and buy a gasket set, and repair manual yank the head off take it down to a machine shop and see that lip on the head whack it off or leave a little bit showing put it back on w/new gasket, yank off you flywheel w the proper puller get the old drill out and wallow out the holes to advance the timing this will usually get about +2+3 degrees advance buy a set of fmf or procircuit pipes if you are not around water yank that air box off and get a set of longest k+n's that will fit the carbs buy a set of boyesen carbon 2-stage reeds, make sure that you jet it correctlly this should give a noticable increase in the power all they way from the bottom to the top and should pull very strongly in the upper rpm's all this is realitively cheap and easy to do if you want more top end get the pro's or if you dont trail a lot or sit in closer to the bike get the cpi inframe pipes and get your cylinders ported not all out drag port but a good useable play/trail port this combo would be brutal in the drag strip. Quote
