1999shee Posted June 13, 2014 Report Share Posted June 13, 2014 Hey Guys need some help , - 1999 shee with stock box and fmf exhaust system , had an idle issue so I Upped my pilot to a 27.5 from a 25, mains are 270's, now as soon as I start it it revs to the moon !, carbs are syncd no air leaks , could a slide be in wrong? float stuck ? (has tors eliminated) cables are not pulled out of the caps and the slides are touching the bottom of the carbs .... thoughts ???? Quote Link to comment Share on other sites More sharing options...
1999shee Posted June 13, 2014 Author Report Share Posted June 13, 2014 Im starting to think I have the wrong slide in the wrong carb......I thought they were both the same ? and the same bowl came off and went on the same carb so cant be that Quote Link to comment Share on other sites More sharing options...
Joeladm Posted June 15, 2014 Report Share Posted June 15, 2014 The he slide that goes on the left side has a notch cut out on the top on both sides, front and back. The right side only has one side notched out. Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted June 16, 2014 Report Share Posted June 16, 2014 Choke tube between the carbs maby. Quote Link to comment Share on other sites More sharing options...
