hp2000 Posted June 13, 2014 Report Share Posted June 13, 2014 FmF Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
DBR06Banshee10 Posted June 13, 2014 Author Report Share Posted June 13, 2014 So what about shearer???? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 13, 2014 Report Share Posted June 13, 2014 So what about shearer???? Sent from my iPhone using Tapatalk They're good if you want the second or third best pipe for that motor. I'd run: Sniper CPI Shearer In that order. Quote Link to comment Share on other sites More sharing options...
DBR06Banshee10 Posted June 14, 2014 Author Report Share Posted June 14, 2014 They're good if you want the second or third best pipe for that motor. I'd run: Sniper CPI Shearer In that order. So does the big bore or small bore play a big difference? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 14, 2014 Report Share Posted June 14, 2014 So does the big bore or small bore play a big difference? Sent from my iPhone using Tapatalk yes Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
driftingbanshee Posted June 14, 2014 Report Share Posted June 14, 2014 Cpi! And if you wanna be a cheap kent then poor man's are like $399 in raw dont talk to morons you only educate them.. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 14, 2014 Report Share Posted June 14, 2014 So does the big bore or small bore play a big difference? Sent from my iPhone using Tapatalk Yes. You want small bores. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 14, 2014 Report Share Posted June 14, 2014 Cpi! And if you wanna be a cheap kent then poor man's are like $399 in raw dont talk to morons you only educate them.. Who is that directed to? Quote Link to comment Share on other sites More sharing options...
driftingbanshee Posted June 14, 2014 Report Share Posted June 14, 2014 Who is that directed to?dbro personally if I was building a motor or the likes I'd go LED to spec. yes expensive but will get most out of your motor. splash the cash on building it why not match it with a specific product and not something of the shelf. Quote Link to comment Share on other sites More sharing options...
99michael Posted June 14, 2014 Report Share Posted June 14, 2014 So what's the skinny on the slp? I seen they did great on jd's stock cylinder. How would they do on a serval? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 14, 2014 Report Share Posted June 14, 2014 So what's the skinny on the slp? I seen they did great on jd's stock cylinder. How would they do on a serval? Very similar results. They would be comparable to CPI I'm guessing. I'll see if I can get Cam to run a set on a 4mm Serval. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 14, 2014 Report Share Posted June 14, 2014 ^ waiting to see those results as well. Quote Link to comment Share on other sites More sharing options...
gusto Posted June 14, 2014 Report Share Posted June 14, 2014 Check the hp/tq numbers in the dyno section on the PC's with a serval. It's impressive...and there cheap! Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 14, 2014 Report Share Posted June 14, 2014 when i asked mr sniper about sniper pipes on a 4mm as cast serval, he said the those pipes wont suit the low timed serval. has anyone ran sniper's on as cast 4mm serval ? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 14, 2014 Report Share Posted June 14, 2014 when i asked mr sniper about sniper pipes on a 4mm as cast serval, he said the those pipes wont suit the low timed serval. has anyone ran sniper's on as cast 4mm serval ? I don't think so but so far every motor we've tested them on worked best with Snipers. One of those was a 10mm Serval. Quote Link to comment Share on other sites More sharing options...
