fox_forma Posted June 12, 2014 Report Posted June 12, 2014 Got a weird one here and got my new crank but seem to have a bit of a stalemate with it going in. The old 4mil hotrods had an o-ring on the flywheel side and used a c-clip on the other side. The new one has o-rings for both sides so should the c-clip that goes in the case to hold the crank be removed and just use o-rings? I read on hotrods site that the o-rings are in place of those clips now. So which is the way as I have now read both ways are proper. Sent from my VS980 4G using Tapatalk Quote
trickedcarbine Posted June 12, 2014 Report Posted June 12, 2014 Pull the O ring off the PTO side. Use the OEM clip. If you are that far in though with a 4mil, get a second half mood or a full clip from fast. Quote
fox_forma Posted June 13, 2014 Author Report Posted June 13, 2014 Pto side..... the clutch side assume and what do you mean by if I'm that far in order another half moon or full clip? Thanks for the quick response Sent from my VS980 4G using Tapatalk Quote
trickedcarbine Posted June 13, 2014 Report Posted June 13, 2014 If you are as far as splitting the cases, it's best to plan ahead and do everything you can to help with reliability. IE, the second clip on the clutch side (pto) crank bearing. Another thing to not forget, put some ultra grey on the clutch side crank key. Maybe a little trans work if you can afford it. Check the trans bearings out. You can use a max load type crank bearing on the output shaft side of the trans. I also double clip that stuff to if it's got the grooves in the cases top and bottom. Quote
fox_forma Posted June 13, 2014 Author Report Posted June 13, 2014 What's the disadvantage to running only one clip? This motor is going back together tomorrow so I don't have time to order another clip to double up. Sent from my VS980 4G using Tapatalk Quote
