ksw390 Posted June 5, 2014 Report Share Posted June 5, 2014 2 questions I got the carbs off the bike they have 148 mains looks like m45 pilots can't get them to stop leaking even while the bike is running leaking out both sides and the bottom. Is there a certain way to set these floats. The bike has a la sleeve 409 mono-block complete big bore kit. Cpi out of frame pipes. It runs really well pulls hard. I'd like to put this motor in a regular frame. And get some different pipes. But i know nothing about the motor or the build on it. Any suggestions on doing this Any thoughts or suggestions Sent from my SAMSUNG-SM-N900A using Tapatalk Quote Link to comment Share on other sites More sharing options...
ksw390 Posted June 5, 2014 Author Report Share Posted June 5, 2014 Sent from my SAMSUNG-SM-N900A using Tapatalk Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted June 5, 2014 Report Share Posted June 5, 2014 Polish the seats, check float height. Then new needle valves. what kind of angle are they at on the bike? Quote Link to comment Share on other sites More sharing options...
sick421 Posted June 5, 2014 Report Share Posted June 5, 2014 I would switch the o ring on your seats, and replace the needle valve Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ksw390 Posted June 7, 2014 Author Report Share Posted June 7, 2014 New seats fuel leak fixed now onto the second part of the question would a build like this be fine to run as a regular driver. I usually just ride dirt toads and trails go to the sand occasionally. Sent from my SAMSUNG-SM-N900A using Tapatalk Quote Link to comment Share on other sites More sharing options...
sick421 Posted June 7, 2014 Report Share Posted June 7, 2014 I would put in frame pipes and a shorter swinger and it should do fine . If its drag ported it will lack in the the bottom , and be too violent on the top . But it all depend on what caliber of a rider you are . I dune and trail a drag ported cub and i rip rocks at anything that is close behind me lol Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ksw390 Posted June 7, 2014 Author Report Share Posted June 7, 2014 I'll have to put the motor over in my other bike and get diff pipes this frame can't really be rode unless it's drag it dont turn for crap stretched out in the front as well as the plus 6 or 8 swinger Sent from my SAMSUNG-SM-N900A using Tapatalk Quote Link to comment Share on other sites More sharing options...
sick421 Posted June 7, 2014 Report Share Posted June 7, 2014 Yeah get a nice a arms stock frame Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ksw390 Posted June 7, 2014 Author Report Share Posted June 7, 2014 Choices Or just pic up another frame and do a build I'd like to pic up a frame with a title and not mess with my 06 the 2000 blue one is a champ no reason to switch motors in it. But no title on it. Sent from my SAMSUNG-SM-N900A using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 8, 2014 Report Share Posted June 8, 2014 Try that cub in that yellow SE. It would be bitchin' on the back roads and open trails. Cubs aren't so friendly in the tight stuff, but you could totally clutch the hell out of it and make it through. Just takes a lot more stamina. Quote Link to comment Share on other sites More sharing options...
