Deleted TORS, now issues
We bought two Tors eliminator kits for identical banshee's.
First one we did was my quad. Worked like a charm. Runs good idles fine. DONE
Second kit went on friends. installation went smoother than mine. Fire it up and right side cylinder is missing. you can see the right exhaust will stop blowing smoke every now and It also bogs when trying to rev it up.
We have pulled the carbs off and re cleaned, inspected. Triple checked everything. We didn't change jets or anything. simply just removed TORS.
We swapped plug boots. Problem stayed on right cylinder.
anyone else have similar problem?
My TORS eliminator came with two new caps, so how would switching be attributed to this? Unless I'm misunderstanding what you're saying.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Yes, he has me confused as well.
Come with new tops and cables. The only thing that stays the same are slides and carbs.
Student4life probably meant carb slides and not carb tops. You can't have the slides in the wrong carb or the wrong bowl those 2 parts are specific to each carb.
The half moon cut out faces the rear of the carb if they are in wrong it will run like shit
