jacowils Posted May 30, 2014 Report Share Posted May 30, 2014 I have an 87 with the 4 bolts to losen on the carrier. I wanted to tighnten my new chain up so i did and the chain adjuster bolts show the exact same number of threads becuase i adjusted them together but it still seems as if the axle isnt aligned properly how can this be? Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 30, 2014 Report Share Posted May 30, 2014 Different length bolts? Quote Link to comment Share on other sites More sharing options...
jacowils Posted May 30, 2014 Author Report Share Posted May 30, 2014 Yes the bolts are the same size i measured them, and it could be an optical illusion becuase it looks fairly straight to me i just want it perfect to avoid premature sprocket wear. Should i trust the bolts and just eye the sprocket and if it looks good roll with it? Thats basically what my clymers manual says to do Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted May 30, 2014 Report Share Posted May 30, 2014 The manual should include details on how to order a swingarm that's 10 pounds lighter with a Honda style carrier. Best mod ever! Well.....getting better front shocks is the best mod ever. Honda carrier is a close second. Quote Link to comment Share on other sites More sharing options...
Banman1122 Posted May 30, 2014 Report Share Posted May 30, 2014 Line it up by eye and run it. Sometimes the chain guide can make it look like it's off. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 31, 2014 Report Share Posted May 31, 2014 Use a caliper to measure. Quote Link to comment Share on other sites More sharing options...
