Just got new pistons and rings. Do I need to hone cylinder
I did a compression test on a banshee I just picked up and it was reading 30 so I took the jugs off and found the rings were broke. The cylinders look good inside and are smooth. I mixed the cylinder and they are still with stock perimeters so I ordered stock 64 mm pistons and rings. My question is do I need to hone the cylinders before installing the new pistons or can I go ahead and install. I have never had to hone a stock bike before but I see a lot of people on here saying they did it when they replaced the pistons.
Thanks jamie
You need to check them with a micrometer and a telescoping gage to check the bore an inch down and in 6 places. Top mid and bottom front to back and left to right. A caliper only can check the top and bottom the middle is very important to check as well.
